Doors hanging a little low
Old Feb 15, 2011 | 11:00 AM
errose2002's Avatar
Default Doors hanging a little low
Hello All
So since my 98 is drying out, I was thinking about the doors. They seem to be hanging a little low, especially the rear door. Is there a good write up on how to adjust the doors so they are hanging better? I know on my sister-in-law's chevy truck I bought some thick nylon washer for the pins which positioned the door correct again. Is that what needs to be done on the Disco's?
Thanks
ed
Old Feb 15, 2011 | 11:21 AM
Chris-bob's Avatar
I'd like to hear any responses as my front pax door is rubbing on the pillar.
Old Feb 15, 2011 | 02:26 PM
errose2002's Avatar
This is what I got from RAVE, but not sure when I get the shims.
Adjust the door by adding or removing shims
between the hinge and the door to move the
door forward or rearward in the opening.
9. To adjust the door up, down or in and out of the
opening, loosen the screws securing the hinges
to the door, adjust as necessary and retighten
the screws to the correct torque value.
10. Adjustment of the door striker is identical to the
procedure for front doors.
Old Feb 15, 2011 | 06:36 PM
I have yet to adjust the doors on my Disco but on every other car I have owned when needed I just loosened the hinges from the body, moved the door and tighten the bolts.
Old Feb 15, 2011 | 10:22 PM
errose2002's Avatar
Spike
Do you think that will that work with the big rear door as well?
Old Feb 16, 2011 | 12:53 AM
Chris-bob's Avatar
Originally Posted by errose2002
Spike
There was a TSB for the rear door. It would rattle/clunk when going over bumps. Had to do with the plastic guide wearing out and allowing the door to 'wobble' when closed. Probably, with time, it allows the cargo door to sag if left unrepaired.
Jawbox
Jul 8, 2013 07:47 AM
tooltech
Sights N Sounds
Mar 30, 2013 07:03 AM
TRIARII
Sep 1, 2012 03:39 PM
wynhd
Aug 28, 2012 11:33 PM
lennie5936
May 28, 2008 07:54 AM
