Drag link removal from arm
Old Mar 21, 2013 | 05:13 PM
FINDingCLARITY's Avatar
Default Drag link removal from arm
First semi-major maintenance done on my disco, drag links were pretty loose. Ordered two of them and they will be here tomorrow but I can't seem to get the old ones loose. Any recommendations?
I went to my auto parts place in town and got one of these things to pop them off the steering arm.
http://www.planetisuzoo.com/data/art...-remove-hi.jpg
Do I need this to get them removed? LRT-57-018? Any advice?
Old Mar 21, 2013 | 10:04 PM
XCELLER8's Avatar
your new tool should work.....get it tight and then hit the puller bolt or the old ball joint with a BFH....the shock of that should make it cooperate.
could also heat it with a torch if you have one available
Old Mar 21, 2013 | 10:29 PM
fishEH's Avatar
If you're junking the old TRE's just hit the end with a BFH, it'll pop loose. One time I stuck a floor jack between the top of the TRE on the drop ARM and the frame to get the TRE to pop loose.
You'll probably have a more difficult time unthreading the old TRE's from the drag link.
Old Mar 21, 2013 | 11:22 PM
Sorry, yeah I am having a crappy time trying to get the TRE off of the drag link. I got the clamp loose but the are like welded to the drag link lol. Wish I had a torch and a vice
Old Mar 22, 2013 | 12:48 AM
fishEH's Avatar
You'll most likely need a torch, even a Home Depot one with some Mapp gas should work. A vise, pipe wrench, cheater bar, and PB Blaster are needed too.
If you ever plan on offroading your truck now is the perfect time to drop $100 on a HD drag link and save yourself the headache of trying to salvage the old one.
Old Mar 22, 2013 | 07:55 AM
CUpgt's Avatar
What brett said
Old Mar 22, 2013 | 10:19 AM
Probably right, worth getting the whole set from lucky8 and save myself from headaches later on.
Quick question, when installing them back do I need to put some lube on the TRE and the steering arm?
Old Mar 22, 2013 | 01:45 PM
JPSpen's Avatar
A little anti sieze couldn't hurt...
JOhn
Old Mar 22, 2013 | 04:23 PM
fishEH's Avatar
I always completely cover the TRE threads with antiseize when installing. They come out real nice then.
Old Mar 22, 2013 | 05:31 PM
CUpgt's Avatar
Most aftermarket HD drag links will come with a RH and LH TRE. Im pretty sure stock set up is RH RH. Just before you get a suprise
