drive shaft q
Old Mar 20, 2014 | 05:46 PM
TOM R's Avatar
Default drive shaft q
I am pretty sure I know the answer but aren't the u joints supposed to be in line looking down the shaft?
Just making sure since some things on rover seem to not stick with conventional thinking
Reason I ask is my front shaft is clocked like 45* out and I have a vibration I can't fix that has always been there
Old Mar 20, 2014 | 07:37 PM
CUpgt's Avatar
When you say clocked you mean the yokes are 45* out? You should be able to remove the shaft, pull it apart at the splines and align it. Might want to have it balanced while your at it.
Old Mar 20, 2014 | 07:49 PM
TOM R's Avatar
Yes that's what I mean and what I just did to rec lock it, will see how it is, there are no weights on it which I find a little odd
Old Mar 20, 2014 | 11:23 PM
CUpgt's Avatar
Mine has a weight but it's a little jacked up from some sort of contact. I'm debating whether or not to upgrade the rear shaft
Old Mar 21, 2014 | 04:42 AM
antichrist's Avatar
D1 front propshaft u-joints are supposed to be phased 45 degrees from each other.
Old Mar 21, 2014 | 08:07 AM
TOM R's Avatar
Whoops guess its back under the rover to change it back ugh, thanks anti
Wonder why?
Also noticed I have what's left of a white decal wrapped around the shaft, maybe been replaced?
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
blackdisco2001
Mar 10, 2007 02:14 PM
BMWLR
Sep 28, 2006 10:33 AM
dchyun
Mar 23, 2006 01:50 PM
