drive shaft splines coated with plastic?
the splines on my rear driveshaft yoke are coated with plastic. I had to beat the yoke off with a 5 lbs sledge hammer and its not going back on easy with that plastic coating. I guess it's there to protect the metal but its making it really hard to install drive shaft since I can't compress or extend shaft.
I'm thinking about removing the plastic..has anybody did this?
Sorry, just had to be a *****.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
No I have not done this.
it fits fairly tight now but I can see how over time It might loosen up. This rover will not driven daily, so maybe it will be a long time before I need a new yoke. I had no other option, once that glide coat starts to peel re-installing the yoke into shaft just makes it peel more.
also, I don't like drive line components I have to beat with a sledge hammer in a vise. I prefer a little bit of play so I can get it apart on the trail if need be.
