drove through a lake of a puddle, now issues with starting
Old Apr 29, 2014 | 12:36 PM
slskier88's Avatar
Default drove through a lake of a puddle, now issues with starting
Drove through a giant puddle yesterday and the car wouldn't start after I stopped, made a weird clicky noise too. Let it dry over night and had no issues staying it this morning. But now it s doing the clicky noise again and will not turn over. What should I do?
Old Apr 29, 2014 | 01:42 PM
slskier88's Avatar
What other info may you need?
Old Apr 29, 2014 | 01:44 PM
TOM R's Avatar
What year? Gas engine?
slskier88's Avatar
1997 and yes gas engine
Old Apr 29, 2014 | 01:47 PM
slskier88's Avatar
I was thinking that water got into the distributor and got something wet that shouldn't have gotten wet but now I'm not sure
Old Apr 29, 2014 | 01:49 PM
slskier88's Avatar
Are you able to post a video or sound byte on here? That way people can get a better sense of what I'm talking about
Old Apr 29, 2014 | 02:13 PM
slskier88's Avatar
Idk if this would help but I hooked up my code scanner and it keeps reading that there is a link error
Old Apr 29, 2014 | 02:24 PM
slskier88's Avatar
Ok, if anyone has any interest I can email you the video of what happens when I turn it on and try to turn it over. Thanks for all the help!
Old Apr 29, 2014 | 04:00 PM
ajnolin's Avatar
Check ecu. Had the same issue going through a car wash (I know, there's a first and last time for everything) and found ecu soaked, and corrosion. don't ignore the basics, battery leads, starter connections, grounding points
Old Apr 29, 2014 | 04:11 PM
slskier88's Avatar
Ok perfect, I will check all those out. Thank you ajnolin
