E-brake is getting insanely hot.
Old Mar 26, 2012 | 08:21 AM
attackRus's Avatar
Default E-brake is getting insanely hot.
Just what the title says. After about a 15~20mins drive its to hot to touch. The brake light isn't on, nor is the e-brake pulled. The funny thing is if you pull it the radio shuts off for a little bit (just the sound the actual radio doesn't seem like its affected). Same if I turn my lights on or switch between norm and brights.
Old Mar 26, 2012 | 08:40 AM
leadfoot's Avatar
What do you drive?
Old Mar 26, 2012 | 09:04 AM
attackRus's Avatar
Oh sorry XD I really should put that in my Sig.
1999 Land Rover Discovery I
Old Mar 26, 2012 | 09:24 AM
leadfoot's Avatar
Weird issue. There tow possibilities for it getting hot, one is adjustment, in which case the brake pads are too tight and rubbing against the drum or electrical issue. In this case it sounds sounds like a wiring issue. Like a hot wire is rubbing against a part of the park brake mechanism causing a very minor short circuit.
Old Mar 26, 2012 | 02:16 PM
Cosmic88's Avatar
Default Now That'a a FIRE!!!
Deal with this quickly... Here is a possiblly related and previously observed issue
Need help identifying the cause of a fire - DiscoWeb Message Boards
Old Mar 26, 2012 | 02:42 PM
attackRus's Avatar
Where should i start? i have no idea how to remove the center console.
Old Mar 26, 2012 | 03:33 PM
attackRus's Avatar
Alright so I've figured out its the actual break cable thats getting hot. where do you guys think its getting hung up on?
Old Mar 26, 2012 | 03:36 PM
leadfoot's Avatar
I would try to follow the cable from underneath and look for any electrical cable on the way, you get pretty far up following it, though more than likely the issue is way inside the center console, there are lost of wires there.
Old Mar 26, 2012 | 03:38 PM
attackRus's Avatar
I pulled the console off as much as i could to get at the e-brake and it doesn't look like anything is rubbing on it or even open wire.
Old Mar 26, 2012 | 03:52 PM
leadfoot's Avatar
Check the switch and wiring that turns the parking brake light on on the dashboard.
