electric fans
Old Nov 19, 2010 | 02:10 AM
colanne's Avatar
4th Gear
Default electric fans
1995 Discovery TDI electrical problem with air con. Fans come on with ignition, ac switch has no effect.
Old Nov 19, 2010 | 06:54 PM
Do they even come on when the engine is stone cold?
Old Nov 20, 2010 | 02:56 PM
colanne's Avatar
4th Gear
Default a/c problems- electric fans on 95 Disc.
Yes. Fans come on immediately the ignition is switched on. I had extensive work done eg new head and suspect something has been hooked wrong but I can't find it.
Old Nov 20, 2010 | 04:46 PM
Take it back to the shop that did the work, they messed it up they should correct it.
Old Nov 20, 2010 | 06:29 PM
Spencerfitch's Avatar
head work really shouldnt have damaged the switch.. But thats probably what it is.. The switch.
Old Nov 21, 2010 | 01:07 AM
colanne's Avatar
4th Gear
Default electrical fans
Work was done abt 2000kms away therefore impractical
Old Nov 21, 2010 | 09:19 AM
Well then it has to be a bad switch or sending unit.
If the ECU thinks the engine is overheating it will turn those fans on.
If the ECU thinks the A/C is on it will turn those fans on.
I would turn the key on and the A/C off and then with the fans running unplug the engine temp sensor, if they shut off replace that.
If they stay on plug that back in and then unplug the A/C compressor.
If they once again stay on then I am out of idea's.
Old Nov 26, 2010 | 02:26 AM
colanne's Avatar
4th Gear
Thank you Spike. Following your advice I eventually found that the person who replaced head etc had reversed the two similar sensor plugs below the thermostat. When I pulled one the fans stopped. I changed them over and , bingo, everything was back to normal. Thank you again. colanne.
Old Nov 26, 2010 | 03:37 PM
Thank you for posting fix.
Now if someone else has a similar problem and they do a search maybe this will help them.
mydisco03
Apr 12, 2011 03:23 PM
03discoman
May 10, 2010 05:10 PM
kenk
Aug 19, 2009 08:25 PM
wilson96rr
May 31, 2009 10:07 PM
mitsi88
May 7, 2009 08:57 PM
