Electrical Gremlin Strikes 97 Disco?
Turn key to start car... Wipers came on when applying brake pedal... Locked in park.... Also Both front and rear Wipers come on when you turn on light switch...... Brake lights work?
Was able to get out of park and into neutral by by pulling the wiper stalk back to activate washer fluid? Car starts and does run fine.
Ignition barrel kinda sloppy lose... could this be some kinda steering column ground fault/short?
Thanks... John
1997 Land Rover Discovery
185,000 miles. All Stock No Mods.
Thanks... John
Have a Tuesday appointment with the"Stealer"
Have managed to keep it out of there for a decade but this one has me stumped.
Any more thoughts?
There is a ground terminal behind both kick panels and on either side of the dash supports at the tunnel. There are a few more in even tighter spots up under the dash and a couple at the mid and backside of the trans hump. The kick panels take maybe a minute to remove..... easy check for busted ground studs, water ingress and smoked relays.
I'd take a look at why they were so corroded to begin with. You may wind up back at the same point otherwise. Any leaks in the windshield seal? Or clogs in the sun-roof drain lines? etc.
