Electrical Help Needed
Please take a look at the following connectors (in photo) and see if you can id what they belong to. I just bought a 95 DI and I am in the process of inspecting and setting it back right. I tried to use the RAVE manual, but the pictures are in black and white and don't give great help regarding the wire colors, etc. These undone connections are located under the steering column near the interior fuse panel. Any help would be appreciated.
Usually things in the yellow tape are air bag related. Cant make out exact colors on the mystery plugs. The harness frequently has plugs for options not installed.
as for colors, in the first part of the wiring diagrams you'll find a table. So as an example, pink = K, brown = N, blue = U, etc. You can then do a simple search on the drawings by inputting KU, for pink with blue stripe. It will find every connector with a wire that color on it.
Just checked my 95 DI and I have the same plugs un plugged. However, does your cruise control work? One of the plugs in the second picture either the one on the far left or right (left of the other plug) is for the cruise control brake switch.
DiscoIIBrandon
Jul 13, 2011 09:25 PM
