Electrical Problem - Main plus connector
Old Nov 1, 2012 | 10:13 AM
Kalimian's Avatar
Default Electrical Problem - Main plus connector
Hay all,
I've just bought a 1997 Disco V8. It had several owners before and it seems that one of them, for some reason, decided to connect the permanent plus electric wire to the car's switch.
As it happens, I don't have interior cabin lights (unless the switch is on), the clock and the radio resets them self and so on.
Any ideas where should I start looking for this connection?
Regards,
Yaron.
Old Nov 1, 2012 | 11:25 AM
You can download the whole RAVE shop manual set, it contains the electrical diagrams and wire colors. You'll have to disconnect one end of the "after market" wire to do any diagnostics. They could have installed if they had a problem with alarm immobilization, or the Multifunction unit is bad (behind fuse block, controls timing and dimming of interior lights), etc.
NESkier
Mar 1, 2015 06:59 PM
caymandrew
Jul 13, 2013 10:47 AM
alexLandRover
Sep 8, 2012 01:32 AM
b63215b
Jul 30, 2012 11:33 AM
Snafu / Disco Fries
Apr 13, 2011 05:40 PM
