Engine Code Scanner and Fuse Tester Recommendation
Old Nov 1, 2016 | 01:53 PM
JUKE179r's Avatar
@Toran
Do have a link to these LED fuses? That sounds interesting!
Old Nov 1, 2016 | 04:51 PM
aemnky606's Avatar
https://www.amazon.com/Bussmann-ATC-...ords=led+fuses
Old Nov 5, 2016 | 05:42 AM
Toran's Avatar
I like these too!
ATO Automotive Blade Fuse with LED Indicator | eBay
Old Nov 10, 2016 | 11:30 AM
colemtd's Avatar
Originally Posted by ihscouts
Your right, just like watching you, how ironic.......
Ha Ha..
Old Nov 10, 2016 | 11:33 AM
colemtd's Avatar
Originally Posted by WaltNYC
If you have a "smart phone" there is a cheaper and, imo, easier way to read codes and monitor data supplied to the ECU. It is a matter of preference.
https://landroverforums.com/forum/di...02/#post581013
your truck originally came with a fuse puller (instead of needle nose). It may be long gone but this is where it started.
Oh yeah. I do believe it is still there. I guess I just like my needle nose. I will check this out..
Old Nov 10, 2016 | 11:35 AM
colemtd's Avatar
Originally Posted by Toran
Thanks Toran, so theses fuses flash or the LED light goes out when the fuse is blown so you can easily tell which are blown and which aren't?
Old Nov 10, 2016 | 11:37 AM
colemtd's Avatar
Walt, is there a way to program a new FOB with your smartphone as well?
Old Nov 10, 2016 | 11:39 AM
Toran's Avatar
The led is on when the fuse is blown.
This is much easier to identify than having them be lit all the time when working properly.
It would be like looking at bright Xmas lights!
heheehehe
Old Nov 10, 2016 | 11:40 AM
colemtd's Avatar
I am slowly replacing my standard fuses with ones that contain a tiny LED. Now I'll simply be able to look at them without even touching and removing. Could be worth something for ya!
OK my apologies, I asked the question that you answered already.. Should have read the responses in order That is absolutely awesome. I will get some STAT...
Old Nov 10, 2016 | 11:41 AM
Toran's Avatar
Its all good!
