Engine missing/bogging while driving at 2000rpm!?!
Old Oct 24, 2010 | 08:14 AM
Jull's Avatar
Bad gas and the need of a tune up. This should clear most of the problems. If a good tune up doesn't clear the issue and the check engine you can start to dig deeper. Do not forget the truck sat for 2 years, time has the same effect as mileage.
Old Oct 24, 2010 | 01:37 PM
booper169's Avatar
Where can i get a new VSS im from ontario canada..??
Old Oct 24, 2010 | 03:46 PM
Jull's Avatar
www.roverparkboys.com they are in Alberta
www.britrest.com they are in Lennoxville Qc
www.roverbec.com they are in Laval Qc
or the nearest stealership
You can also try www.roverparts.com or www.roversnorth.com but they are in the US and they overcharge for shipping in Canada IMO.
A VSS is close to 150$. I think you would be better to give the truck a good tune up if it's not already done before buying a VSS.
Old Oct 24, 2010 | 05:45 PM
booper169's Avatar
okay i put the fuel filter in... still does it.. i put spark testers on the end of the plug wires and plugged them onto the spark plugs... they light up fine when its idleing but when i rev it up to 3k the spark cuts out and they dont flash normal.... any ideas?
VSS?
i cleaned the maf sensor...
Old Oct 24, 2010 | 06:00 PM
Bad gas wont cause you to loose spark.
But a bad VSS or coil will.
Cam sensor controls injectors.
Crank sensor controls spark and fuel pump power.
Old Oct 25, 2010 | 07:10 AM
booper169's Avatar
It misses when it's in park and I rev it. Could that still be vss or would vss only act up while it's moving
Old Oct 25, 2010 | 07:34 AM
Thanks Phil, I wasn't paying attention to the model. Yes, a speed switch will be the most likely issue so follow Phil's post and replace the switch, clear the codes and see what shows up.
With your mileage, you should also be replacing all 4 02's as well as the cam sensor, if it doesn't go away after clearing the codes.
Old Oct 25, 2010 | 08:01 AM
Jull's Avatar
If the truck does it in park wouldn't it eliminate the bad VSS possibility?
Old Oct 25, 2010 | 08:20 AM
I do not know that answer.
Old Oct 25, 2010 | 04:47 PM
booper169's Avatar
Can someone please tell me where the crank sensor and where the vss is
