Error codes on 1996 Discovery
Old Jul 30, 2013 | 10:54 AM
Michael Haas's Avatar
7th Gear
great advice; thanks. Do you know what part I have to replace that is throwing that P1178 code?
Old Jul 30, 2013 | 11:29 AM
while it could be an O2 sensor, you could also look for a dirty air filter, etc.
Old Jul 30, 2013 | 02:21 PM
7th Gear
Thank you!
Old Jul 31, 2013 | 08:16 AM
DiscoJag's Avatar
I get the P1178 every couple of months or so. The truck runs fine and passes inspections as long as it has run long enough after I reset the code. I believe it means that the ECU is saying that it is adding fuel to the mixture at the max amount compared to it's base fueling map. Which means I probably have a vacuum leak somewhere. I can't find a vacuum leak to save my life, and the code only pops up every couple of months, so I've just put up with it. I have cleaned the MAF and throttle body to no avail. If you guys do find a cause, I would be very interested. Cheers.
pixel
May 13, 2011 07:24 PM
hollis
Feb 15, 2008 08:29 PM
JUSTINFO69
May 25, 2007 09:28 AM
asterix
Oct 26, 2005 07:23 PM
