Exhaust leak? Vacuum leak? video.
Old Aug 20, 2012 | 08:50 AM
WaltNYC's Avatar
Default Exhaust leak? Vacuum leak? video.
OK. I'm hearing a new and small sound of air 'puffs'. Here's a video. Fairly sure it is not 'mechanical'. (sorry to link out rather than embed)
Old Aug 20, 2012 | 10:34 AM
If you want to find the problem don't wait for us to be of much help without you checking every square inch of exhaust system and then water testing for a vaccum leak.
By the way, those old factory plug wires are not helping your engine perform well if you have over 50,000 miles on them, need some 8 mm silicone replacements.
Old Aug 20, 2012 | 10:47 AM
WaltNYC's Avatar
Hey Mike...looks can be deceiving. Those are 1yr old, 8mm Kingsborne wires. They are a bit messy because they don't fit in the factory looms as you probably know. I should make them a bit neater I suppose and put them in the looms I bought with the wires. I did do that to help routing back to the coil packs but didn't do any routing with the new looms alongside the valve covers.
Please tell me about water testing. Are you talking about spraying small amounts of water with perhaps a tiny soap additive to check for bubbles to check for vacuum leaks?
Old Aug 20, 2012 | 10:55 AM
Time for me to get new glasses. As for the noise, what I hear or what it sounds like to me is a pulley bearing noise.
If it were vacuum, you would have a possible high idle, rough running and certainly some fault codes, if it were an exhaust leak, you would have a soot stain on the header, exhaust pipe or gaskets.
Don't worry about it being a vacuum leak without codes.
Old Aug 20, 2012 | 11:00 AM
WaltNYC's Avatar
Thanks Mike. I'll do some more poking around.
If anyone else has any ideas, shoot them in. Watching a video is certainly not the best diagnostic tool but I'm all ears.
Old Jul 27, 2015 | 02:24 PM
WaltNYC's Avatar
Reviving this old thread.... The answer is.... the spark plug was not seated properly.
twaszak
Jul 15, 2012 07:21 PM
Street Wolf
Jun 24, 2011 01:59 AM
Switzer
Aug 13, 2009 04:23 AM
Torancis_LR
Jun 19, 2009 11:59 PM
mr_boondoggle
Jan 19, 2009 02:15 PM
