Exhaust manifold replacement
Old Oct 7, 2015 | 07:59 AM
DiscoXD_mike's Avatar
7th Gear
Default Exhaust manifold replacement
Hey everyone, I'm replacing the exhaust manifold and gaskets on my '97 disco XD. The passenger gasket is completely blown and the manifolds are in bad shape. Anyone have any tips for an easier removal process? I've sprayed down the bolts with some PB blaster to make them a little easier to remove. The lower manifold connection to the Y pipe is a bit rusted so if I have to drill out the studs I will.
Old Oct 7, 2015 | 08:23 AM
drowssap's Avatar
is it the top gasket next to the head, of the one that connects to the exhaust pipe?
Old Oct 7, 2015 | 08:38 AM
7th Gear
It's the main gasket where the block and manifold meet that's gone bad. I'm sure the lower gasket is bad as well. I'm replacing all of them to be sure.
Old Oct 7, 2015 | 02:57 PM
Racer X's Avatar
Lots of heat and patience if you want it to come apart without breaking studs.
I have neither of these things, so I just ordered a couple of used ones on eBay, replaced the studs with new, and swapped them out while replacing the gaskets.
Old Oct 8, 2015 | 06:39 AM
drowssap's Avatar
i say leave the bottom alone unless you know its leaking and just replace the exhaust manifold gaskets.
twaszak
Jul 15, 2012 07:21 PM
bcolins
Sep 10, 2008 02:16 PM
raid13
May 13, 2007 10:22 AM
portman
Jan 3, 2006 05:26 AM
beavis4g63t
Jul 12, 2005 05:27 PM
