Eye ball Lift/Tire size.
Old Mar 22, 2011 | 09:31 PM
AuZZZie's Avatar
Default Eye ball Lift/Tire size.
For you guys that have been around Rovers longer than myself (pretty much everyone) do you think you could eye ball what size lift/rubber this guy is running?
YouTube - Camelo
I'm thinking about a 2" w/ 245/75/16. What do you guys think?
Old Mar 22, 2011 | 11:20 PM
CUpgt's Avatar
2" with 265/75R16 would be my guess
Old Mar 22, 2011 | 11:21 PM
AuZZZie's Avatar
I would like a little more width, as I find the stock look a little sunken. How is the fitment with 265's?
From my reading I know 245/75/16 will fit nicely with a 2" lift.
Old Mar 23, 2011 | 05:10 AM
hilltoppersx's Avatar
depends on what lift you use. i have the terrafirma and its actually a 2 1/4" lift all around i run 265/75 and the height is fine but the width sucks. i can't turn i need wheel spacers now.
Old Mar 23, 2011 | 08:23 AM
thehun's Avatar
agree...it makes a bit more
Old Mar 23, 2011 | 08:55 AM
kenk's Avatar
I run 2" of lift w/ 245/75's. Absolutly no trimming needed, did have to adjust one side for turning radius to stop rubbing on the control arm at full-lock turning.
D1's almost always need some triming to run 265/75's with only 2" of lift as they have smaller wheel well opening's than the D2's
The guy in the video looks like he's running maybe 2"-3" of lift. Red springs may be these(only red springs I've ever seen):
Discovery I 3" Lift Springs
Discovery I 3" lift springs set of 4 medium duty, without the harsh ride, color options, red or black.
$344.95
LRDITSI113
Old Mar 23, 2011 | 10:39 AM
AuZZZie's Avatar
Thanks for the input guys... So you are rubbing the fenders with 265/75.. How exactly would spacers help? Wouldn't that just push you wider into the fender more?
Old Mar 23, 2011 | 10:49 AM
not rubbing fenders rubbing radius arms. the wheel spacers will give me the space i need to regain my full turning capability.
Old Mar 23, 2011 | 10:51 AM
AuZZZie's Avatar
Ohh that makes more sense.. What size spacer are you thinking you will need to clear? I might just go that route right off the bat as I wanted a little fuller look anyways.
Old Mar 23, 2011 | 12:08 PM
whatever i can get cheapest. new spacers run $400 USD. i know someone who got a used pair of steel spacers for $100. I prefer 30mm but 1 inch spacers will do me fine.
SuperSport
Sights N Sounds
65
Oct 17, 2014 12:35 PM
ellebarto
Sights N Sounds
Dec 10, 2013 05:02 PM
Rover Rebel
Jan 29, 2011 08:34 PM
d2luvr
ROAMING WITH FRIENDS
Jul 23, 2010 09:15 PM
goldfishy
Jan 23, 2008 03:46 AM
