fan clutch question
Old Jul 1, 2012 | 12:20 PM
Captian Adrianus's Avatar
Default fan clutch question
I know the fan clutch should not spin freely when cold and only should just move slightly when I try to spin it. mine does just that. The question is... if I keep trying to spin it will it start to move freely? When my engine is cold and i try to spin the fan, it only moves slightly but, if i keep spinning it it starts to free up and eventually can get it to spin about 1 and a half revolutions. Is this normal?
1995 Disco 3.9L
Old Jul 1, 2012 | 03:28 PM
You now need to spin the fan when the engine is hot.
It should be 2 times harder to spin when hot then cold.
Old Jul 1, 2012 | 04:33 PM
Ok. thanks. I'll try that as soon as I get the radiator back from the shop.
Old Jul 1, 2012 | 07:23 PM
It will loosen up the more it spins, all of the fluid inside it settles to the bottom overnight and once it spins it re-distributes and allows the fan to spin freely.
In the tech section is a cheaper alternative.
Scharfire
Jul 6, 2021 02:59 PM
jafir
Feb 10, 2017 11:08 AM
Thatdudeuno1
May 1, 2012 05:10 PM
dino109
Jan 1, 2012 03:38 PM
rover1978
Sep 26, 2009 09:05 PM
