fast blinker
Old Aug 7, 2014 | 06:28 PM
TOM R's Avatar
Default fast blinker
Dumb question, are the left and right turn signals on separate flashers?
My left blinks normal, right blinks super fast like a bulb is out,
no bulbs are out
Old Aug 7, 2014 | 07:10 PM
ihscouts's Avatar
Same flasher, check the stalk switch.
Old Aug 7, 2014 | 07:36 PM
geek_IM's Avatar
no bulbs are out
Mine is exactly the same. Left is normal, right is fast, and will slow down and speed up some too.
Since it still works, haven't messed with it. I was told by a somewhat dubious source that it is caused by having the wrong type of bulb in it, that different resistance in the circuit is causing the issue.
Old Aug 7, 2014 | 07:50 PM
TOM R's Avatar
Started when I blew a bulb in the bumper, replaced bulb still blinks fast, what am I looking for in the stalk?
Old Aug 7, 2014 | 07:51 PM
Buddy Lee's Avatar
Are you sure you don't have a bulb out? Did you replace one with a lower wattage bulb or LED?
Old Aug 7, 2014 | 08:23 PM
TOM R's Avatar
Put the brake bulb in signal then replaced brake bulb with one I had
Old Aug 7, 2014 | 08:46 PM
Buddy Lee's Avatar
strange, maybe try switching the bulb out with a correct wattage one. The only time I've seen the signal blink fast is if there was reduced load on the circuit. That's one of the reasons I keep my signal bulbs from the bumper taped up under the truck. I'm too lazy to but resistors in and don't like the fast blinking if I pull them out.
Old Aug 7, 2014 | 09:07 PM
TOM R's Avatar
On my dodge I changed to all led and just had to install a HD flasher for normal blink, when we build my new rear bumper I was gonna delete the bumper lights anyway
Old Jul 2, 2015 | 12:52 PM
TOM R's Avatar
well endeded up getting a ep26 flasher cheap on amazon, made the pigtails since it will not fit in fuse box and flashes normal now, but the trailer indicator does not come on when i signal like it used to??? i have not checked my trailer harness plug to see if it is working properly
Old Jul 2, 2015 | 01:35 PM
fishEH's Avatar
My trailer lights still worked fine after installing the EP26.
