Floor Redo - Rust Treat - Paint - Diamond Plate
Old Oct 28, 2011 | 07:25 AM
slanginsanjuan's Avatar
Default Floor Redo - Rust Treat - Paint - Diamond Plate
I'm finishing my rustproof and new diamond plate floor on my D1.
-I ripped almost everything out of the interior.
-I power grinded and wire brushed the floor.
-I cut out small bits of unrepairable rust.
-I used KBS Klean to remove all residues.
-I used KBS Rust Blast to burn the rust off and prepare for painting.
-I used KBS Seal in black to cover all exposed metal and create a hard finish.
-I made a template of the floor in order to cut the diamond plate just right. I need to finish positioning of bolt holes for seats and belts.
To do this weekend...
-I need to find a good panel adhesive and some marine caulk to finish up the floor.
-I plan on running some galvanized metal strips along the perimeter to strengthen the floor support.
-Cut and patch the few wall or front floor holes with sheet metal to cover exposed holes. Patch and paint.
-Weld a couple stays to the floor.
I'm getting on it shortly.
Note: That third pic demonstrates my saggy ***.
Attached Thumbnails Floor Redo - Rust Treat - Paint - Diamond Plate-2011-10-24_07-54-18_354.jpg   Floor Redo - Rust Treat - Paint - Diamond Plate-untitled-0-00-11-06.jpg   Floor Redo - Rust Treat - Paint - Diamond Plate-3.jpg   Floor Redo - Rust Treat - Paint - Diamond Plate-kbs.jpg   Floor Redo - Rust Treat - Paint - Diamond Plate-unknown.jpg
Old Oct 28, 2011 | 07:29 AM
Here's the template. I can probably save it for anyone who needs it.
Attached Thumbnails Floor Redo - Rust Treat - Paint - Diamond Plate-2011-10-27_16-20-21_960.jpg   Floor Redo - Rust Treat - Paint - Diamond Plate-2011-10-27_16-20-46_577.jpg
Old Oct 28, 2011 | 07:52 AM
hilltoppersx's Avatar
looks like your daughter is going to fail elementary art class now that you stole all her construction paper.
Old Oct 28, 2011 | 08:07 AM
Sam95disco's Avatar
too funny
Old Oct 28, 2011 | 08:13 AM
Ed - Actually she'll probably fail geometry. It looks like a twisted map of the US. Art supplies we got...all over the place.
Old Oct 28, 2011 | 09:49 AM
I think it would make great garage wall art.
Looking good, you should be done by Día de Reyes.
Old Oct 28, 2011 | 10:29 AM
DiscoBlanco's Avatar
Honestly, what you should to is transfer that to a piece of 1/4 hard-board. Trace it out, rough cut it, and sand/file down the edges.
Now your hardboard is a working template. Do your final fitting with the hard-board... Take off a little with a file here or there as needed. Drill your seat-belt holes, fuel pump hole, etc.
Now you have a final template....
Transfer that to your aluminum plate. Cut it out about 1/8" bigger. Trace it with a carbide template bit on a router (your gas tank hole too). Now you have a PERFECTLY fitting piece of diamond plate AND a PERFECT template that you (or fellow enthusiast) can use over and over again.
Old Oct 28, 2011 | 10:45 AM
DB....Why do that extra step? Your way is museum quality. I'm doing above hack/DIY and many shops level but not made for TV. I can lay this down nicely on the diamond plate. Tape the outline and then use my cutting wheels on my hand grinder. It's tight but I allowed for shift. I'll definitely file down the edges. That's not going to be hard.
Old Oct 28, 2011 | 10:46 AM
It's definitely going on the workshop wall where the headliner now hangs.
Old Oct 28, 2011 | 11:45 AM
And should be signed by all persons involved with the project, down to the pizza delivery guy who has kept you going...
