Four wheel drive
Old Mar 1, 2015 | 06:08 PM
Britchick1980's Avatar
Default Four wheel drive
So today, I managed to get myself stuck on a pile of snow. I was well and truly not going anywhere so I had to get my husband to help me. He noticed that only one back wheel was spinning. So he seems to think that I do not have 4 x 4 capabilities. I insisted that land rovers were permanently 4 wheel drive. Who is right? And why would only one wheel spin? The other back tire was on frozen ground, the front ones were on the road. I couldn't engage the diff lock as the lever is seized. It's a discovery 1.
Old Mar 1, 2015 | 07:24 PM
Without the diff lock engaged on the center diff you have 3 open differentials. So the power will take the path of least resistance. Which would be the one spinning tire.
You do have full time 4wd but with 3 open diffs until you fix the shifter. Than at least you can spin two tires.
Old Mar 2, 2015 | 05:53 AM
MM3846's Avatar
Yea, you need to fix the CDL.
Old Mar 2, 2015 | 10:48 AM
WaltNYC's Avatar
In an 'open' (not locked) differential, power travels to the wheel that will spin most easily.
Old Mar 3, 2015 | 03:20 PM
Fenix's Avatar
My CDL was also jammed. The safety actuator failed and wouldn't allow the lever to move. I removed the actuator lubricated the linkages and it works fine now.
It seems like a common problem
Old Mar 3, 2015 | 05:45 PM
fishEH's Avatar
Basically the Disco is full time AWD, while the wheels maintain traction/contact with the ground. When you lock the center diff it becomes 4WD. However, if you get cross-axled and one front/one rear lose traction you won't go anywhere.
Locking the center diff makes a world of difference.
buck1x
Jan 23, 2011 03:39 PM
luxury1
Dec 2, 2008 07:35 AM
BENROVERN
Nov 5, 2007 09:19 AM
noemad
Apr 16, 2007 10:45 AM
Landzu
21
Jun 11, 2006 05:23 PM
