A-Frame Balljoint
Old Dec 4, 2021 | 11:03 PM
disco96sd's Avatar
Default A-Frame Balljoint
My a-frame ball-joint looks perished and just recently I have started having this intermittent noise coming from the rear - not constant - nothing else looks amiss - nothing lose or broken I can see
Can anyone describe the noise of a worn out a-frame ball-joint ?\
Thanks
Old Dec 5, 2021 | 10:00 AM
Best4x4's Avatar
Mine made an awful creaking sound like a coil spring without the rubber isolator.
Old Dec 5, 2021 | 11:40 AM
disco96sd's Avatar
this is more like a periodic thumping / vibration kind of like something hitting on plastic not banging on metal
Old Dec 5, 2021 | 01:16 PM
WaltNYC's Avatar
are your shock bushings, rear trailing arm bushings, and anti sway bar bushings in good order?
Old Dec 5, 2021 | 04:08 PM
disco96sd's Avatar
trailing sway bushings good - rear passenger shock leaking a bit - a frame ball joint boot trash
Old Dec 6, 2021 | 06:57 PM
Mark G's Avatar
I was going to say shock bushing too. Don't forget to check the fronts. It might seem like it's coming from the rear, but could be in the front. My front L just started 'clunking' the other day. Bottom shock bushing. Don't let it go on too long, if that's what it is, it might ruin your shock.
Old Dec 6, 2021 | 09:17 PM
disco96sd's Avatar
Thanks guys
Old Dec 6, 2021 | 10:17 PM
Best4x4's Avatar
Mine sounded more like a bad tie rod end, but only over bumps or when flexing. It then got squeaky, the 45 degree unit with a zerk fitting is a good idea if you off road and flex a lot.
garywwood
LR4
Aug 12, 2020 08:32 AM
dasherman
Jun 1, 2018 08:05 PM
KernowDiscovery
May 30, 2014 10:44 PM
pickps
May 14, 2007 12:42 PM
jodilynne516
Apr 9, 2007 02:52 PM
