front shocks on 95 disco
Old Nov 9, 2010 | 11:45 PM
SkyHigh95's Avatar
Default front shocks on 95 disco
my 95 disco has a front lift coil spacer lift and the bottom of the front shocks arent even bolted down (came this way) and i dont see how they are supposed to be bolted, does anyone have a pic of the lower front shock mounting so i can compare?
Old Nov 10, 2010 | 03:33 AM
Long Haul's Avatar
Take your 2 bolts that hold that hold the spacer on out and put a jack between the axle an frame (be carefull not to stretch brake lines,abs,etc) and you can get to the bottom stud. The spacers are hollow in the center where the stud bolts threw.
Old Nov 10, 2010 | 09:03 AM
They should be attached, what brand of shock is it and are there holes to bolt the lower shoch mount to?
cptshanman
Sep 21, 2017 12:32 PM
arnottdoug
Apr 26, 2012 01:39 PM
cptshanman
Sep 1, 2008 12:25 PM
rphotographer
Dec 20, 2007 01:03 PM
baysentp
Aug 10, 2007 06:15 PM
