fuel filter
Old Jun 23, 2012 | 07:12 PM
discoguy96's Avatar
Default fuel filter
Any major preferences for fuel filters, or any to stay away from specifically?
Old Jun 23, 2012 | 08:16 PM
fishEH's Avatar
I use a generic NAPA one that has a barb on each end. Much easier to change.
Old Jun 23, 2012 | 09:05 PM
I always get mine at Wal-Mart.
Old Jun 24, 2012 | 11:33 PM
wheelgarage's Avatar
Walmart! Must be the FRAM brand right?
I've only used Mann filters 3x. Never had any issues for the past 10+ years...
Old Jun 25, 2012 | 02:53 PM
olywa's Avatar
i just picked up a fram, going to do this now. depressurizing the fuel the rave has mfi, mpi sfi, how do i know which one i have? I know i should already know.
Old Jun 25, 2012 | 03:07 PM
pinkytoe69's Avatar
Im pretty sure that:
MPI = Diesel
MFI = pre-GEMS/non-AEL
SFI = GEMS/AEL
Old Jun 25, 2012 | 03:08 PM
fishEH's Avatar
Start with a cool engine. Stick a rag over the schrader looking valve on the fuel rail and depress the pin in the center of it. The fuel will squirt out into the rag and depressurize the system. Those pliers that pinch off the fuel line are handy too.
Old Jun 25, 2012 | 04:59 PM
olywa's Avatar
It was to pull the fuel pump relay. Passage side. But I don't see blue base.
Old Jun 25, 2012 | 09:15 PM
The MPI is the 4-cylinder petrol engine that was a option for these trucks.
Over head cam, multi port injection.
No need to release fuel pressure, just unscrew the fuel filter, it will depressurize when you do, you will get a dribble of fuel, you will loose about 1 cup worth of fuel.
You can start the engine and remove the fuel pump relay, once the engine stalls you will be fine.
Forget the repair manual on things like this, its just common sense.
Old Jun 25, 2012 | 09:16 PM
Yup, sure is, never had any problems with them.
Its just a fuel filter, its $10.
Perfect fit.
