Fuel injection controller....
Old Jun 10, 2012 | 09:33 AM
ngarover's Avatar
Default Fuel injection controller....
Might be the wrong name but it the computer mod located on the pass side. I know it says something about fuel injection... anyways, can I completely remove it? Does is also power the fuel pump or anything else I should know of?
I'm in the process of removing any and all unnecessary systems/wires etc from the truck in prep for this engine swap...
Old Jun 10, 2012 | 09:44 AM
That is the engine ECU.
The cam sensor controls the injectors.
Old Jun 11, 2012 | 07:22 PM
ngarover's Avatar
So being the engine is gone, there should be no reason I could't cut it and all it's wiring out right?
Old Jun 11, 2012 | 09:19 PM
I cant say for 100%, I dont know your plans are.
Old Jun 11, 2012 | 10:21 PM
Jake1996D1's Avatar
Keep everything until the new engine runs.
Old Jun 12, 2012 | 01:19 AM
ValveCoverGasket's Avatar
as your new engine should only require one or two wires to start/run, id say just follow the main harness from the ecu and remove everything connected to the engine controller...
Old Jun 12, 2012 | 05:44 AM
ngarover's Avatar
1 wire actually, just the wire to the glow plugs.
Thinking about reusing the rover fuel pump as a backup to the manual lift pump hence the question about it being ran though the fuel injector control...
Truck happens to have a brand new fuel pump in it with only 30 miles on it.
JumPeR04
Apr 1, 2011 04:15 PM
lennie5936
May 7, 2008 09:07 PM
bobm
May 6, 2008 08:18 PM
kenlen
Apr 21, 2007 07:08 PM
savatage
Feb 12, 2007 07:25 PM
