Fuel Injectors Clicking when I turn the key.
Guys,
A new problem popped up. I put the key in and turned it, the only response
was a rapid clicking noise. I raised the hood to undo the ground cable and the noise was coming from some of the fuel injectors, I am pretty sure. I had switch the key off but the noise continued.
Lifted the battery cable, noise stopped, reset the battery cable and tried the key again. Same response. Lifted the battery cable and stopped for the day.
Any leads?
Any leads?
This morning, I checked all the grounds visually, all looked good, hooked up battery negative cable, it fired right up and ran smoothBUT TACH IS DEAD!!!
My first time ever that the tach has acted up. Anyone got any ideas what could cause tach to stay at 0?
After posting, I did a search and found this:
https://landroverforums.com/forum/di...ponding-40459/
So I called the local recycler. They just got a DI in and will be pulling the alternator for me, they will call me when it is available.
Thanks to all for your help.
rezzrover
May 7, 2013 06:02 PM
domyo
Sep 25, 2008 12:19 PM
tbraith
Jan 15, 2008 01:24 PM
