Fuel pressure at rail
My truck has been stalling and won't hot restart...sometimes. I thought I may have tricked it by unplugging the fuel temp sensor which seemed to work for awhile with no ill effects. Yesterday I got booted in a parking lot since it stalled, and I had to leave it for a few hours to cool off. I haven't been able to check the spark yet when it is in a no start mode, so I can't tell if it's a CKP sensor problem.
I just accessed the fuel pump to test it a little. The truck has been sitting all day, so will crank fine. I only turned the key to the on position and ran back to hear if the pump ran for it's 10 second prime. I could hear it, so I put a tire gauge (all I have) on the schrader valve on the fuel rail. A little fuel came out but the tire gauge registered zero. I then turned the key off and back on to re-pressurize the rail. I then just stuck a screwdriver on the schrader valve's plunger expected it to spray out pretty far since it should be 35psi. Well, it only shot a sad little stream that barely reached the valve cover, then nothing more. Is that normal? I thought 35psi of fuel should do a little more than that. No codes except for disconnected fuel temp sensor.
mine was the same, ran great, then occasionally no hot start, then more frequent no hot start. It was a combo of dead fuel pump/clogged fuel filter.
I bet your fuel pump is on its way out. When I bled down the pressure in the line even with my dying pump there was a LOT of pressure in the line.
tazzybaby
09-17-2012 11:24 AM
JumPeR04
04-07-2011 09:52 PM
JumPeR04
04-01-2011 04:15 PM
