fuel pressure sensor
Where is the fuel pressure sensor located on a 98 d1?
I have something sucking voltage from my TPS and a wire diagram I was looking at shows fuel pressure sensor tied in with it
Now the rave shows the wire splits off from the TPS at s148 goes through c1026 and c2082 ending at c407 and says not used this is circuit diagram 5 section A3 electrical manual
In the shop mech program my friend showed me same diagram and it showed hooked to a fuel pressure sendor
Providing your '98 has AEL the Fuel Pressure Sensor is apart of the fuel pump.
RAVE has the sensor as X320 (top of fuel tank). The connector is C484. Page 69 under COMPONENT LOCATION VIEWS.
tazzybaby
Sep 17, 2012 11:24 AM
pietch
Dec 2, 2008 10:44 PM
