Fuel Pressure Sensor
Old Sep 3, 2014 | 08:01 AM
SCme's Avatar
Default Fuel Pressure Sensor
My new-to-me 1998 Disco threw a code the other day and it turns out it is the fuel pressure sensor. These are located on top of the (now discontinued) fuel pump in this model, and cannot be purchased individually without the pump. Anyone know if I can get away with changing just the sensor, and if so where to find one? I can't even find a part # for it from LR since it is attached to the pump.
1998 Discovery, 4.0
Old Sep 3, 2014 | 12:58 PM
TOM R's Avatar
unplug it before it shorts your tps, yes I am serious it will short your tps to ground trip ecm to high idle and require the ecm be reset, dig through my thread you will find it and see how I know, I got a used sender from a member here in calif. no issues
the sensor is a permanent part of the fuel sender not serviceable need a good used sender or buy a new one for the crazy money they want at one of the rover parts houses
Old Sep 3, 2014 | 03:29 PM
abran's Avatar
Ive got a good used one if you need it, PM me
Old Sep 3, 2014 | 04:29 PM
TOM R's Avatar
Think mine came from a ran I believe that sensor turns on the purge valve on the charcoal canister?
Old Sep 6, 2014 | 11:29 PM
XCELLER8's Avatar
2x on at least unplugging the damn sensor before it frys something important.....fried my ecu to need to be reset.....
paul1454
Feb 18, 2020 04:03 PM
TOM R
Jan 5, 2014 09:31 AM
herblatham
Apr 12, 2013 11:13 AM
tazzybaby
Sep 17, 2012 11:24 AM
pietch
Dec 2, 2008 10:44 PM
