Fuel pump
Just replaced the fuel pump in the Gf's 97 Disco. When I pulled the fuel pump I noticed the plug going to the actual pump had some melting. Put everything back together and it ran great. Started right up. Shut it down and went to start it back up and nothing.....It would crank but it was not getting pressure at the rail and I didn't hear it prime at the turn of the key. Checked to see if I was getting power to the pump. No power there. Checked the inertia switch. It was in the correct position. Checked to see if there was power to the fuse. No power to the fuse. Pulled the relay. I am getting power to there. So, should I order a new relay? Anything else I should try before ordering that?
The pump only has connectors, wire, the inertia switch, and the multi-function relay between it and the battery. If you don't have power coming out of the relay - then the relay is bad, or the ECU is not turning it on. The alarm immobilizes by disconnecting the starter relay. So if turning over, it may not be the alarm.
Travelor
09-24-2015 06:11 PM
JumPeR04
04-07-2011 09:52 PM
atikovi
04-07-2007 03:27 PM
