fuel pump help. please!
Old Mar 17, 2013 | 02:48 PM
ipontree's Avatar
I replaced it when I put the GMC pump in. I just don't know what fuel pump has similar specs as a 98 Land Rover. I think it is 35-40 psi and 40-45 GPM that the Land Rover needs .. ?? Does anyone know of a pump that will work for me??
Old Mar 17, 2013 | 03:16 PM
ipontree's Avatar
I replaced it when i put the GMC pump in.
Old Mar 17, 2013 | 09:06 PM
ipontree's Avatar
Old Mar 17, 2013 | 09:50 PM
fishEH's Avatar
I can't recall off the top of my head. Have you searched at all? There's about a brazilian threads on here about fuel pumps and many contain specific part numbers.
Old Mar 18, 2013 | 02:05 AM
tooltech's Avatar
my '99 uses the airtex E8388M (by no means a "cheap" fix...)
i just pulled mine out yesterday morning and soldered new wire for fuel guage sending unit. No way i'm gonna pay $400 - $800 + for a new unit.
Old Mar 18, 2013 | 01:06 PM
fishEH's Avatar
Holy sh*t!!! You know a new one from Atlantic British is only $390, right?
Discovery I Fuel Pump And Sender - Order Land Rover Pumps Online
Regardless, we're talking about replacing just the pump, not the whole assembly. Should be around a $50 fix.
Old Mar 18, 2013 | 01:19 PM
tooltech's Avatar
I've seen some ridiculous prices out there... ($399 cheapest; $868 most expensive). I guess I missed AB.. regardless, they can keep it for that. I hope i won't need a new pump anytime soon!
When and if I do though, yes the pump itself is the only thing I will replace.
Old Mar 22, 2013 | 01:50 PM
ipontree's Avatar
The e83883m is the hole thing. I found a pump with similar specs. IT was for a 93 Buick la saber . It pumps around 36-41 psi. i ordered one should be here in few days. its part number is E3212. will let know how this pans out
Old Mar 22, 2013 | 01:52 PM
ipontree's Avatar
Woodland Park , CO
Old Mar 23, 2013 | 10:10 AM
raeuspius's Avatar
Thank you for the info.I tried to put in my fuel pump off of a 94 GMC suburban(they looked exactly same) and the truck ran rough, looked in to it and found out that the GMC pump only runs at 12 psi. and I think that the land rover has to be at least 35 psi. Does anyone know what pump would be best?
airtex e3270 is free flow 50-60psi. I did the same thing you did and truck ran like absolute garbage. i checked key on eng not on psi and was just over 20... i am actually doing the swap today. will update.
