Fuel pump and injection relays not switching
Old Dec 29, 2010 | 12:44 PM
TbwCurtis's Avatar
Default Fuel pump and injection relays not switching
Hi, I have just aquired a 1995 Discovery 1 3.9l V8i.
I was helping tow a friends caravan when the engine cut out and would not re-start no matter what we tried. Since getting the vehicle home (the shame of being towed by a Sangyong) I checked all the usuals, fuel pipes, filters spark, etc... The vehicle will turnover for a second when left to stand for a while. This suggested a fuel issue. I checked the relays to find both the fuel pump and fuel injection relay did not click/switch in when the ignition was turned on. I checked all the fuses and have started checking the earths, I have also borrowed a different ECU with no result. Is there something I am missing? I have power coming in to the relays but seem to have +v on both of the switching terminals 86 and 87.
Any help would be greatly appreciated!!!
Old Dec 29, 2010 | 01:57 PM
TbwCurtis's Avatar
Ok, So I have reset the inertia switch. Unfortunately this has not helped. Am I correct in saying that the inertia switch is after the Fuel Pump relay? Is the ECU meant to ground the fuel pump relay switch? If so why am I getting a 12v reading on that wire? Can I bridge the fuel pump relay and the fuel injection relay just to start the vehicle as it has been sitting for some tim eand I would like to turn it over!!
Thanks
Old Dec 29, 2010 | 04:40 PM
Chris-bob's Avatar
You say the vehicle will turn over only after sitting for a while...Do you mean start for a little bit, or turn over but not start? And when it doesn't 'turn over', what does it do? Just sit there and nothing...or what?
Old Dec 29, 2010 | 06:10 PM
Long Haul's Avatar
Thanks
Yeah you can jump them to see if thats your problem. I wouldnt recomend leaving them that way but itll work in a pinch.
Old Dec 29, 2010 | 11:40 PM
TbwCurtis's Avatar
The vehicle will run for a little bit then die (approx 1 sec). When it does not run, the starter motor merely cranks the engine. I note that there is no fuel coming out of the schraeder valve thus I know that the fuel pump is not ciming on, I have also had some one stand at the rear of the tank t check if it does, and no go.
I have checked both relays and they are good, yet they are not clicking in. I have 12v supply to both relays, but the earth from the ecu seems is not -ve it is +12v.
Thanks for the help
Old Dec 29, 2010 | 11:50 PM
Chris-bob's Avatar
The ECM should provide the ground for both relays. I do not know which pins at the harness, since I seem to see no wiring diagram in the RAVE.
Old Dec 30, 2010 | 01:30 AM
TbwCurtis's Avatar
Thanks for checking Chris-bob, I was in the process of trying to bridge the relays when my battery gave in, chrging at the moment. Looks like I will need to get a new battery. What size should I use, any makes you can recomend?
Thanks
Old Dec 30, 2010 | 01:31 AM
TbwCurtis's Avatar
Where do I find the crankshaft sensor and could this create the problem?
Old Dec 30, 2010 | 01:32 AM
TbwCurtis's Avatar
Sorry for my ignorance, what is the difference between the ECU and the ECM?
Old Dec 30, 2010 | 08:27 AM
Chris-bob's Avatar
ECU and ECM same thing, different name.
