fuel pump looses power...
Old 02-14-2011, 11:00 AM
dansgt's Avatar
Default fuel pump looses power...
so this is basically an update to my last thread but more specific. problem is the pump only gets power for about 10 seconds, then nothing. this was the case once it started as well. any ideas where i should look next?
Old 02-14-2011, 11:04 AM
Chris-bob's Avatar
Swap the relay for a known good relay?
Old 02-14-2011, 11:08 AM
dansgt's Avatar
i have not yet, letting the battery charge at the moment, but where exactly is the relay?
Old 02-14-2011, 11:29 AM
Chris-bob's Avatar
Taken from RAVE:
The two multiport fuel injection relays are located in
the RH footwell area behind the ’A’ post panel. The
main relay module is energized via the ECM when the
ignition is switched on and supplies current to the
multiport fuel injection system. The fuel pump relay
module is energized by the ECM which in turn
operates the fuel pump to pressurize the fuel system.
Old 02-14-2011, 11:33 AM
Chris-bob's Avatar
Pic of the relays.
Old 02-14-2011, 12:44 PM
dansgt's Avatar
thats different then what is see.
Old 02-14-2011, 01:18 PM
kenk's Avatar
Here's what you're pump relay looks like. It's under the hood, passenger side, along the fender,close to the washer fluid resivoir.
http://www.roverlandparts.com/multif...p-relay-3.aspx
Old 02-14-2011, 01:22 PM
kenk's Avatar
Here it is a little better- but you'rs is not AEL(pre-mid'97), so it may vary slightly.
Old 02-14-2011, 01:51 PM
Chris-bob's Avatar
Sorry, I didn't realize when I pulled the info that those two relays are the furl injector relays, not the fuel pump relay. What Kenk said is correct.
Old 02-14-2011, 02:06 PM
dansgt's Avatar
That's what I thought, how do I test if that's my problem or not.
Quick Reply: fuel pump looses power...
