Fuel pump question...
Old Jan 18, 2014 | 05:08 PM
ESPN's Avatar
Default Fuel pump question...
What should the return line on the fuel pump assembly look like on a 98 D1? Should it drain directly into the the cup on the bottom of the pump assembly, or should it pass through a plastic elbow on the side of the pump?
Reason why I am asking is because I am getting too much fuel pressure. I removed the return line from the elbow and the pressure is now normal. The pump assembly from the tank looks like a pump from a p38 according to google images. I was wondering if there is any difference between a d1 pump and a p38 pump.
Thanks
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
