Funny Starting Change?
Old Aug 31, 2010 | 02:47 PM
Spencerfitch's Avatar
Default Funny Starting Change?
Ok not a problem as of right now, but something has changed..
I usually jump in a turn the key straight to start. And it won't turn over. I have to back off and wait 2 seconds.
It doesn't bother me, its just something changed and im wondering if somethings about to go
Old Aug 31, 2010 | 03:39 PM
ColoDisco's Avatar
No crank whatsoever? This was happening to me and it ended up being the starter.
Old Aug 31, 2010 | 04:37 PM
no crank untill i wait
Old Aug 31, 2010 | 04:51 PM
I would be bothered cause it is not normal and will get worse.
Old Aug 31, 2010 | 05:01 PM
this is what im thinking.
I have a feeling its either the starter or some main power supply, to ecu or starter.
Old Aug 31, 2010 | 05:08 PM
ColoDisco's Avatar
Do you get a click like the starter is engaging? then no crank?
Old Aug 31, 2010 | 05:10 PM
Danny Lee 97 Disco's Avatar
Mine got "touchy", I redid the ground for both the battery and starter and no problems since. I installed new lug to a new spot on the frame with a self drilling bolt.
Old Aug 31, 2010 | 08:09 PM
Had this problem on my last truck and hoping its the wiring.
No the solinoid doesnt click
Old Sep 1, 2010 | 04:11 AM
jbriggs's Avatar
I'm not sure if the 95 is the same as a 96 but mine did this also. Hold the key when it doesn' start and see if it eventually cranks (about 5-7 seconds).
Old Sep 2, 2010 | 11:43 AM
tornado_735's Avatar
Every once in a while, I will get literall a half second pause before mine will crank, but it's never gotten any worse.
