fuses question...help
Old 02-26-2016 | 03:48 PM
CATTIVA73's Avatar
Default fuses question...help
hey guys,
is changing the fusible links in the fuse box located in the engine comp. easy as removing the two screws and replacing the link?
Mine on my 1998 look old and rusty and just want to replace all the fuses inside the box...not sure about the long brass looking ones (fusible links)..is it safe to remove them and screw on new ones???
Thank you
Old 02-26-2016 | 06:22 PM
ihscouts's Avatar
Just clean up contact surfaces, they're working just fine so don't toss them out. If you want new or to have spares go to Rovahfarm.com and buy new. Just for clarification a fusible link is a short section of wire about six to eight inches long that lets go above a certain amperage, it's not a see through hard fuse that fits a socket or is screwed down. I know somebody said this in another post but that is incorrect information..... Apples and oranges.
Old 02-27-2016 | 07:19 AM
CATTIVA73's Avatar
Thanks..I ordered the fuses at Roveahfarm..including the long brass with screw looking ones (fusible links)...Do I just unscrew those and replace with new ones?
Thanks
Old 02-27-2016 | 07:57 AM
ihscouts's Avatar
Welcome, yes, just unscrew them. Atlantic British calls em fusible links too......
Old 02-27-2016 | 11:20 AM
CATTIVA73's Avatar
you're awesome. Thanks.
4x4 Brad
02-26-2016 11:43 AM
dgee03
11-20-2008 06:59 PM
MoNtErover
09-27-2008 09:27 AM
OxyCoRover
01-27-2008 10:56 AM
The Capstone
05-11-2006 01:57 AM
Quick Reply: fuses question...help
