Gas Mileage Survey
Old Oct 11, 2010 | 09:31 PM
Garrett's Avatar
Is awful and horrendous a valid response?
Old Oct 11, 2010 | 09:37 PM
Spencerfitch's Avatar
Disgusting [city] and Stupid [hwy]
Old Oct 11, 2010 | 11:19 PM
'BamaBoy's Avatar
15-16mpg City
18-19mpg Hwy
Volo fuel-saver chip installed, everything else is stock.
Old Oct 12, 2010 | 12:06 AM
TomOwen's Avatar
13.5 - 15(rare) stock DI, 5sp
Mostly around town but occasional 60 mile rt. If stat at 65, might see 15. Inverted after that.
Old Oct 12, 2010 | 12:30 AM
johnkbl's Avatar
Where did you buy the chip? I googled for it and there are several versions with the same name... maybe are copycats of the original.
Old Oct 12, 2010 | 06:54 AM
Jull's Avatar
I get 15.5l/100km average. This exactly the same as a 2010 Dodge Ram with the 390hp 5.7l HEMI hahaha.
This weekend I got the Disco working a little, I transported my wood for this winter. With 2000 pounds of wood in a trailer I got 20l/100km
Old Oct 12, 2010 | 08:48 AM
For all you with horrible mileage, what have you done to correct it? Before you think about chips, which are usually a waste of money do the following. Air all your tires to 40 pounds, replace your air filter, change your plugs and wires, make sure to use 8mm wires, only run 91 plus octane, do an induction cleaning and run a can of B&G's 44K thru your tank, then look at your mileage.
Surprising what a good tune will do.
Old Oct 12, 2010 | 10:23 AM
yloDiscoII's Avatar
www.voloperformance.com
Looks like there are 3 of us in this thread using the FS1, the FS3 is the newer version.
Old Oct 12, 2010 | 11:49 AM
ColoDisco's Avatar
This is exactly what I have done minus the FI service. I know I need
to do that as well.
I get
16 city and 20 hwy with my 33" tires. I have them all 4 aired up to 40 psi, I have run 4 cans of 44k through my rig in the past year. 1 every 3 months. Getting ready to do the FI service and replace the fuel filter which looks like it has not been done in some time. I have also repacked the bearings recently and put a thinner weight oil in all 3 diffs in hopes of getting the gears all cleaned up and any debris loose from the internal housing, but am getting ready to put the thicker stuff in with BG MGC in both front and rear and the LSII in the center diff. Not sure if this will effect my mileage.
Being a tech I am always striving for better mpg the natural way. I only chip if I have to. From what I have read about the chips is they take fuel away at cold start which is where our engines suck up the most fuel. As long as there is no power loss at higher rpms I am generally all for it.
Old Oct 12, 2010 | 12:31 PM
Pull that thin gear oil or you will loose your spider gears, I run 85W/140 for extra wear protection and still get 18.2 on the road at 6000 feet as long as I don't go over 70 MPH.
Cut you B&G back to 1 every 6 months unless of course, you are burning swamp gas.
