Gear oil - 80/90W synthetic versus 85W/140 for HD use
Old Apr 5, 2014 | 10:08 PM
  #21
CUpgt's Avatar
I think I've dropped my rear Diff oil 4 times in the last month. 5 gallon bucket of coastal for me!. Going to run Mobil1 in the case.
Old Apr 6, 2014 | 07:42 AM
  #22
TOM R's Avatar
Yeah my concern is expense but I only seem to get water in the diffs sitting in water for 10 minutes not driving through it
Old Apr 7, 2014 | 05:40 PM
  #23
jalodge's Avatar
Originally Posted by CUpgt
I love 85w140 in the diffs. Just recently started running it in the case and it's getting noise. Also leaking. I'm going to drain it, take a peek under the inspection plate and refill will 75w90 and see if it changes anything
So would you say 85w 140 in the diffs and 80w 90 in the t case?
Old Apr 7, 2014 | 05:53 PM
  #24
TOM R's Avatar
Thicker in t case to take up slop
Old Apr 7, 2014 | 05:59 PM
  #25
jalodge's Avatar
So 85w 140 all around?
Old Apr 7, 2014 | 07:05 PM
  #26
TOM R's Avatar
Probly OK since you live in a warm area
Old Apr 7, 2014 | 08:58 PM
  #27
jalodge's Avatar
Are there any negative affects to running the thicker oil?
Old Apr 7, 2014 | 11:37 PM
  #28
CUpgt's Avatar
You can feel the resistance in the thicker oil on cold mornings but I don't know if it will hurt anything. I'm going to go back to thinner oil in the case. The guy that set up my rear end suggested dino 80/90 or 85/140. Said not to run synthetic, no clue why but he used to work for Richmond Gear and has been building rear ends for 30 yrs so I take his advice.
Old Apr 8, 2014 | 07:08 AM
  #29
TOM R's Avatar
I had the Dino 85/140 all around, 15* temps the rover struggled to move, like I said the heavy royal purple in rears and 80/90 in case was a huge difference
Ian you get the locker all fixed?
Old Apr 8, 2014 | 11:32 AM
  #30
CUpgt's Avatar
Yep. Back in business
