general ultragauge question
Old Nov 10, 2012 | 09:27 AM
discoguy96's Avatar
Originally Posted by Spike555
If you guys read the directions you would see that the U-G uses the MAF, road speed, RPM, engine temp...to calculate the MPG readings.
Mine is fairly accurate in my lifetime average, it is only about ~1mpg low on the U-G when compared to the app on my phone.
U-G says 13.4, actual is 14.5.
The "miles til empty" function will not work because there is no fuel sender.
Did you do the distance and fuel calibrations or did the mpg function work for you right out of the box?
Old Nov 10, 2012 | 11:11 AM
Worked for me right out of the box discoguy96.
The only problem is the decimal point is in the wrong place, so my MPG on the U-G reads 1304.6 instead of 13.046
Old Nov 10, 2012 | 03:28 PM
discoguy96's Avatar
Ahhh ok, that might be what I'm seeing too. I'll have to recheck that.
Thanks.
I assume you're using the MAF and not MAP with VE enabled, right?
Old Nov 10, 2012 | 04:07 PM
Um, sure?
I'm using the default setting on that part.
I've had mine for over a year so I dont remember how I set it up exactly.
But I have never calibrated it.
Eldonkey
Oct 18, 2013 08:41 AM
Snafu / Disco Fries
Jan 25, 2013 09:43 PM
discoguy96
Nov 11, 2012 07:12 PM
tornado_735
Apr 27, 2009 10:45 PM
Sfef84
Feb 21, 2008 07:56 PM
