Getting the car ready for smog check
Old Sep 1, 2016 | 02:11 PM
photo2u's Avatar
Default Getting the car ready for smog check
HI friends,
In my attempt to get my car register I must get my 95 disco smog.
I am located in California and my local smog check person is not a very friendly person to deal with. The car was none operational for a little more than two years. The car is running ok but i want to prep the car so that it will pass the test. Last time it was smog it pass with no problems.
Does any one have any advice for getting this old warrior pass?
I welcome your comments and advise.
Thanks!
G.
Old Sep 1, 2016 | 03:12 PM
Shiftonthefly1's Avatar
Run a tank of premium gas in it. Change the oil. Change the fuel filter. Cap rotor wires are cheap.
Old Sep 1, 2016 | 04:48 PM
photo2u's Avatar
I see, What about the timing? any advice? Some one mention to advance it a bit?
Thanks for the info.
Old Sep 2, 2016 | 09:40 AM
Yea you can play w the timing. I've heard rubbing alcohol in the tank helps too. Never tried it. I look at smog tests as good thing. I want it to be running as it should. So I usually don't try the tricks
Old Sep 3, 2016 | 11:30 PM
SocalD1's Avatar
Run premium fuel a tank or two, get it good and hot run 20 min or so on the freeway just before you take it in to test. New spark plugs are a good thing too!
Good luck!
Old Sep 4, 2016 | 03:23 PM
photo2u's Avatar
Good luck!
Thanks for the advice! I was just thinking the same.
Proto31
Feb 6, 2015 02:36 PM
USNAVYORDNANCE
Jan 2, 2015 09:58 PM
Joshman
Mar 3, 2014 11:30 PM
Camdisco24
Feb 23, 2008 06:41 PM
shendren
Defender
Jan 22, 2008 01:22 PM
