Is GL5 in a Tcase ok?
Old Sep 14, 2010 | 07:40 AM
anything old's Avatar
Default Is GL5 in a Tcase ok?
Hi everybody, i read the sticky on tcase fluid change ran down to walmart grabbed a bottle and changed it. I was looking around on here at the conversations and back and forth on GL5 and im just looking for some input. I cant find anywhere on the bottle about it being GL4 safe. I'll swap it out if it needs to be done. Thanks for any info.
Old Sep 14, 2010 | 08:49 AM
What weight and brand are you talking about? I used to run a GL6 in the diffs and t/case and switched over to Mobil 1 in a 75W/140 along with 1/2 pint of Lucas Stabilizer in the rear diff to keep the Detroit happy.
Old Sep 14, 2010 | 09:01 AM
Its supertech 85-140 the same stuff in the sticky. Thanks
Old Sep 14, 2010 | 09:55 AM
Go for it, works well in hot weather and no ill-effects in the cold weather we have in Colorado.
Old Sep 14, 2010 | 10:07 AM
Thank you.
Old Sep 14, 2010 | 08:24 PM
That stuff IS GL-4 and GL-5, so you are safe.
GL-5 that is NOT also GL-4 rated will eat brass, we have brass inside our diffs.
Old Sep 14, 2010 | 09:47 PM
Thanks, one of your old posts said NOT to use GL5 unless it was GL4 rated and i couldn't find anything on the bottle so i decided to ask.
Northtosouthkaz
May 7, 2013 08:34 AM
RacerX
Dec 5, 2012 11:21 AM
kevinb91
14
May 25, 2012 09:42 AM
EstorilM
Oct 11, 2011 08:13 PM
brooksa
May 24, 2008 10:40 AM
