good tire pressure
Old Jul 19, 2010 | 07:13 AM
Silver_Slug's Avatar
Default good tire pressure
What is a good tire pressure on a 245/75 R16?
Old Jul 19, 2010 | 08:12 AM
Tire size makes no matter on tire psi.
I run mine at 40psi on all four.
Old Jul 19, 2010 | 09:14 AM
XCELLER8's Avatar
2x on 40psi
Old Jul 19, 2010 | 10:08 AM
yeah because the book was like 26 front 34 rear and that just seems too little.
Old Jul 19, 2010 | 11:57 AM
antichrist's Avatar
The correct pressure depends on the tire, it's load rating, and the axle loading you have.
You can't say x pressure for y tire.
There are two ways to get the correct tire pressure for your setup.
1. Chalk the tire and roll the vehicle to see the tread pattern it leaves and adjust the pressure based on the pattern it leaves.
2. Call the tire mfg and give them the tire size, model, load rating and vehicle weight per tire and they can tell you the suggested pressure.
For instance, I called Cooper and these were the inflation pressures for my load range D 7.50Rx16 Discoverer STT's
Loading
per
wheel
in
pounds PSI
2390 60
2190 55
2040 50
1930 45
1770 40
1620 35
Old Jul 19, 2010 | 01:29 PM
Right now i have the cooper Discovers stt or somthing... so should i be good with 40 psi?
Old Jul 19, 2010 | 01:36 PM
antichrist's Avatar
I wonder.
Old Jul 19, 2010 | 02:45 PM
well how much about does a discovery S1 weigh?
Old Jul 19, 2010 | 02:50 PM
antichrist's Avatar
I give up.
Old Jul 19, 2010 | 03:17 PM
im talking about day to day driving. no added load besides the weight of the car.
