Got A Code 45 HO2S Right Bank
Right as I'm driving or as I'm looking at the engine?
Its been raining heavy, crossed some water bout 1/2 wheel high, once I got home the truck was still running fine. I let it idle for 2min before I cut it off. When I returned to start it Check Engine light was on and OBD read 45. I checked the wires to both sides and everything is conected, I felt the wire to see if any were damaged all seem fine. What gives?
If the wire was damaged while driving shouldn't it have cut off on me?
I may just change them all along with new wires.
Weeeee weeeee more work... :-l
Get the 8mm in the color of your choice. And purchase some spacers as well since the 8mms won't fit in the stock routing harnesses.
IGN 785 Kingsborne Spark Plug Wires Ignition Wire Set - Kingsborne Ignition Spark Plug Wires Sets made in the USA
Great QPR. (quality price ratio)
So if I just replace plugs for now till I get these cables I'll be fine? Could the wires be shorted out to?
Do they have any likes the genuine parts? It has a cover for the coil.
http://www.roverparts.com/Parts/RTC6551GD.cfm
