Great the CEL just came on....frick...
Old Jun 20, 2011 | 12:05 AM
wheelgarage's Avatar
Default Great the CEL just came on....frick...
Now my dash looks like a christmas tree.....
Need the this thing to show me the codes.
Old Jun 20, 2011 | 08:56 AM
Okay, i thought about this last night. I am not sure if the 87 gas I put in triggered the CEL.
Old Jun 20, 2011 | 09:20 AM
turf63's Avatar
It def will
Old Jun 20, 2011 | 09:50 AM
Good to know. I really need to replace the filler and vent hose before i fill it up again...
Thanks.
Old Jun 20, 2011 | 10:42 AM
Danny Lee 97 Disco's Avatar
Try Rovers north or maybe even Atlantic British for the correct new hoses, I did mine and it is not that hard. Wash the area good before you start, much easier to do it without stuff falling in your face, since you will be underneath it. And be sure to depressurize the fuel system before you crack anything loose to avoid fuel spraying out undert pressure. A good system should maintain pressure.
Old Jun 20, 2011 | 10:44 AM
Also, avoid the cheap low octane gas, use a good brand of premium. I use either Shell or Sunoco 93 octane. Saving a little bit per gallon will cost you more in the long run. These are designed to run on premium fuel. Otherwise you might as well pee in the tank. Camel **** or water buffalo **** is the best grade of urine.
Old Jun 20, 2011 | 10:49 AM
Good to know that it will run on **** if needed....got it guys....will do.
Going to order the hoses....
Old Jun 20, 2011 | 10:58 AM
Some Bacardi 151 in an emergency. Glad to see you got a good sense of redneck humour. You must be a Jeff Foxworthy and Larry the Cable Guy Fan as well as I am.
I saw a construction worker the other day that looked just like Larry the Cable Guy with his cut off sleeves and ballcap, except for one major difference, this guy was actually working!!!!
Old Jun 20, 2011 | 12:00 PM
Danny....many of my friends are from the Allentown area...so similar humor is normal....dang "Dutch"....lol
Old Jun 20, 2011 | 08:20 PM
CUpgt's Avatar
hell i thought the CEL was a normal thing on a disco
