the great spark plug debaten on D1
Old Feb 17, 2014 | 12:28 AM
TOM R's Avatar
Default the great spark plug debaten on D1
title reflects the war I will probly start posting this but here goes
what spark plug have you had good luck with on the D1? coil pack or distributer ignition?
got to pull one to see what I have but have seen reference to bosch +4 and champion 318??? both run like $4-6 per plug also seen mentioned that on rover not using that champion plug results in premature coil failure? seriously doubt that
Old Feb 17, 2014 | 05:39 AM
antichrist's Avatar
I use whatever the cheapest copper plug is I can find. I usually buy them ahead of time when I get a good deal on them, like 75¢
Never seen any difference in how they run.
Old Feb 17, 2014 | 12:34 PM
fishEH's Avatar
This. Usually that ends up being the Champion or AutoLite Coppers.
Old Feb 17, 2014 | 12:40 PM
TOM R's Avatar
Aren't all the better plugs copper core?
Old Feb 17, 2014 | 12:41 PM
OverRover's Avatar
IMHO, don't waste your time/$ with Bosch Plat +4 or BullSh*t E3s.
I've run Champion Copper with little issues, but in the last few years I have had the best results with NGK #7734 (BPR5ES). Start-up is spot on, and idle (warm or cold) is smooth.
Old Feb 17, 2014 | 10:20 PM
XCELLER8's Avatar
champion RN11YC4, NGK BPR5ES-11, I have used the Bosch platinum +2 and +4's...no noticable difference......
Old Feb 18, 2014 | 05:27 AM
antichrist's Avatar
What do you mean "better"? Copper plugs are the cheap ones that have been around forever.
Old Feb 18, 2014 | 08:19 AM
TOM R's Avatar
I know little about plugs in general other then gaping, use never sieze and dielectric grease, check for defects, and pulling em to try and diagnose drivability issues by their appearance
I know I have never had good luck with champion or auto lite, a lot of times I found the autolites ceramic would fall down and cover the electrode causing intermittant drivability issues, champions seem to flood easily but I am referencing use in carburated small block v8's , I know you will say that just shows there is another problem fuel or spark but when time and again the problem disappears by simply going to AC delco, ngk, Bosch it tells me the plugs are the problem
Think I run the ngk referenced above in my d1 have to pull one to see
Now the wifes Mazda putting in the big $ irridiums increased the MPG a lot so ..........
Old Feb 18, 2014 | 10:42 AM
WaltNYC's Avatar
NGK BPR6ES here. very satisfied.
Old Feb 18, 2014 | 12:40 PM
TOM R's Avatar
I mainly posted this thread to see what guys used on d1 with good results and what worked poorly or was found to be a waste of $ as help for non motorheads
tried making an easily searched topic title but I misspelled it of course but am sure a modd can help.
