Has My Rear Drive Shaft Been Converted?
I have read both here on the forums and in the RAVE that the rear drive shaft on my D1 should have a u-joint at the gear box end and a rubber gaiter (rotoflex?) at the differential end.
Well, mine actually has u-joints at both ends. The previous owner (friend of mine) did not modify this, and I have no knowledge of the 2 previous owners before him doing this, but it seems like it has been modified.
Or, maybe I am just missing something obvious.
Did 1997 D1s switch over to two u-joints?
Already greased them. I figure I will do it at each oil change.
But if you off-road much you're probably better off doing a u-joint conversion anyway. A spinning piece of rubber hanging low on your drive train is asking for trouble.
