Has My Rear Drive Shaft Been Converted?
Old Oct 3, 2010 | 11:00 PM
LeakyDisco's Avatar
Default Has My Rear Drive Shaft Been Converted?
I have read both here on the forums and in the RAVE that the rear drive shaft on my D1 should have a u-joint at the gear box end and a rubber gaiter (rotoflex?) at the differential end.
Well, mine actually has u-joints at both ends. The previous owner (friend of mine) did not modify this, and I have no knowledge of the 2 previous owners before him doing this, but it seems like it has been modified.
Or, maybe I am just missing something obvious.
Did 1997 D1s switch over to two u-joints?
Old Oct 3, 2010 | 11:06 PM
geek_IM's Avatar
I have a '96 I was working on (under) all day and I have the same arrangement as you. I was also happy to notice that they are bristling with zerks as well. Time to get the grease gun warmed up
Old Oct 3, 2010 | 11:39 PM
kenk's Avatar
I don't know the exact date, but somewhere around '96 they switched, 'cause I've seen both(u-joint and rotoflex)
Old Oct 3, 2010 | 11:40 PM
UpChuck's Avatar
From what I remember reading, the D1's had u-joints the whole way 'round, and the rotoflex was introduced with the DII. But I might wrong, if Ken is correct. So your D1 is as it should be...rotoflex free.
Old Oct 4, 2010 | 09:12 AM
No, there was a period of a little over a year and a half that Rover switched back and forth between u-joints and a roto-flex.
If you have a roto-flex, just check it for verticle cracks between the bolts, if u-joints grease them 2 times a year.
Old Oct 4, 2010 | 11:25 AM
antichrist's Avatar
Chris, do you have a concern, or is it just out of curiosity?
As for greasing them, do it according to the instructions in the propshaft rebuild sticky in the write ups. Mike always says 2 times a year, but that's incorrect.
Old Oct 4, 2010 | 11:39 AM
LeakyDisco's Avatar
Just curiosity. Thought maybe a PO may have had it converted from rotoflex to u-joint, but it sounds like that wasn't the case.
Already greased them. I figure I will do it at each oil change.
Old Oct 4, 2010 | 11:56 AM
ColoDisco's Avatar
I have the rotoflex. For anyones info who has the rotoflex. Rockauto has replacements for $20 or so.
Old Oct 4, 2010 | 12:25 PM
My '97 has 4 u-joints, grease them every oil change.
Old Oct 4, 2010 | 02:58 PM
antichrist's Avatar
Just as an FYI, there have been a fair number of reports of cheap rotoflexes shredding.
But if you off-road much you're probably better off doing a u-joint conversion anyway. A spinning piece of rubber hanging low on your drive train is asking for trouble.
