Headlight warning light???
Old Jun 27, 2011 | 02:38 PM
wick_60010's Avatar
Default Headlight warning light???
I have a '99 Discovery I. I recently had problems with my headlights where they would dim or one wouldn't come on, or one would be on bright all the time, etc. When this situation occurs, the high beam indicator (blue) on the dashboard would come on slightly to inform me there was an issue. I replaced the sockets and bulbs in both headlights. They now seem to be working fine, but that dash headlight warning light (high beam indicator) still illuminates slightly. I checked all the fuses, and they're all fine. Why is this light still coming on on the dash? Thanks!
Old Jun 27, 2011 | 08:34 PM
That is not a warning light, that is the high beam indicator.
If it is coming on even when your high beams are not on there is a electrical problem.
Old Jun 28, 2011 | 02:09 PM
wick_60010's Avatar
When the high beams are on, the blue light displays brightly. When they're not on, it still illuminates, but you can BARELY see that it's on. Perhaps a short?
Old Jun 28, 2011 | 02:53 PM
fishEH's Avatar
Perhaps your turn signal/head light stick is faulty? Its a VERY common problem on D1's and a VERY easy fix. You can swap them out in about 15 minutes.
Old Jun 28, 2011 | 02:58 PM
turf63's Avatar
Perhaps you shouldthrow some electrical tape over the indicator light and forget all about it.
cipher982
Nov 9, 2019 11:22 AM
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
Disco03
Dec 1, 2008 08:08 PM
sacconejr
May 24, 2008 07:48 AM
