heat only stays hot for a min
Old Oct 1, 2010 | 11:02 AM
Classklown90's Avatar
Default heat only stays hot for a min
so when i turn my heat on, after the car is all warmed up, it stays hot for about a min and then gradually becomes just cool (not air cond temp and not hot just room tempish). anyone know what the problem is?
Old Oct 1, 2010 | 11:08 AM
leadfoot's Avatar
Vacumm leak. Does the control for directing the air to Windshield, Front and feet work ok?
Old Oct 1, 2010 | 12:42 PM
Necrocom4's Avatar
this is shot in the dark but when i first got the truck the coolant level was only just enough to cool the engine but not get to the heater core. at least thats what i figured cuz once i topped the reservoir off the heat started working again.
Old Oct 1, 2010 | 02:06 PM
leadfoot-im not sure ill check but i know the defroster setting works fine and ill check the coolant as well
Old Oct 1, 2010 | 08:27 PM
bantham1's Avatar
Could be air in your heater core. Does it get hot again when you rev the engine?
Old Oct 1, 2010 | 08:38 PM
discomedic4's Avatar
My vote is for air in the heater core or low coolant. Or both.
Old Oct 1, 2010 | 09:23 PM
Danny Lee 97 Disco's Avatar
How recent is your coolant?
Old Oct 2, 2010 | 10:14 AM
it was actually the coolant level, i never would of thought to look there so thanks necrocom
Old Oct 2, 2010 | 10:20 AM
So, now what are you doing to find your vacuum leak? if you don't find and fix it, you will over heat your engine.
Old Oct 2, 2010 | 10:46 AM
i dont think i have a vacuum leak, all the settings work and it now stays hot due to me adding more coolant
