heater and CC don't work
Check your coolant level...if its normal, your tstat is stuck open.
No, the cc and heat aren't related. Download the RAVE, start there, fuses, switch, cc ecu, all troubleshooting is there, start there.
on
I went and print various sections that pertained to what I was trying to focus on.
That allowed me to read and reread as I used those pages to work my way thru the problems. That is really about the best way to do it as far as I am concerned. A highlighter, a red pen to add notes/questions/wrench sizes (those are never listed in the RAVE), a three hole punch and a three ring binder and before long, you have a nice record of what you have done.
Some people prefer to do it on their laptop, tablet or cell phone, but I am Old School when it comes to that.
I have one binder for the Electrcal T/S Manual and schematics. Another for the parts breakdown pages by system, and another for the general stuff, arranged and cross tabbed by system.
Full of greasy fingerprints and the dates recorded that I did the various things. Make it easy for quick reference when I am down in the garage. Don't need to run up to the computer.
on
Also, if you do not have a good light and a creeper and eye protection, you should get them and crawl underneath and take a tour of her bottom.
See what leaking from where, what's rotted and about to fall off (my rear muffler did one day on the PA Turnpike). I tell people to treat it like you would a woman you picked up at a sleazy bar really close to closing time, get down there and take a good close look and see what you got, just don't get anything in your eyes. You could go blind.
well... i have a black leaky coolant tank. It drops about an inch below fill line and stays there. The gauge on the dash gets to right under 9 o clock and has never risen above. Now two different occasions after turning off the truck maybe a pint of coolant will just poor out. I am getting a new tank this weekend. Im still waiting on my obd2 adapter so that I can get an accurate temp reading. Should I be questioning my gauge though ?
Older Discos - some bypass the heater core to stop leaks, overheating, and hide bubbles in coolant under dash sound. See pix of two variations. Worth while to reverse flush heater core is disconnected. Gauge can read anything it wants to, not famous for being spot on. Pisx with radiator covered to show gauge reading for way to hot in my opinion. And I have run mine when testing without a stat on hot days, temp got to maybe 130 - 140 on scanner. You would not have any heat then. $10 fix. I run a 180F at the moment, 183F at 55, maybe touch 192 for short period in traffic after freeway run.
Also, if stat had been replaced at some time, and allowed to slip down while mounting, it leaves an opening at the top and behaves similar to a stuck open stat.
If it was overheating you would have more heat than you wanted.
