Help?????
Help?????
I just had all 4 Oxygen sensors replaced and the car did great...after a few miles engine light came on again and its giving me the codes: P1187 (2) and P1193 (2) again!
It strange ALL four are listed this time...
Could it be a fuse?
If its a fuse...: which fuse is it ?????
Thank you
Could it be a fuse?
Thank you
..not sure about dielectric grease as I had them replaced by mechanic...does it need to applied on the tips of each Sensor ?
Thanks
Thanks
Cool, if that doesn't work the O2 electrical connectors are probably suspect - hence the dielectric grease. You have an "inferred" short circuit which means it isn't a "confirmed" short circuit. You have two connections between the O2 and the ECM. The O2 connector and the ECM large Molex connector. Either can have corrosion.
alti
03-13-2013 08:30 AM
Speed racer
10-11-2008 10:56 PM
